PCM1793,pdf(PCM1793: 24-Bit 19
消耗积分:5 | 格式:rar | 大小:448 | 2010-06-26
分享资料个
The PCM1793 is a monolithic CMOS integrated circuit that includes stereo digital-to-analog converters and support circuitry in a small 28-lead SSOP package. The data converters use TI’s advanced segment DAC architecture to achieve excellent dynamic performance and improved tolerance to clock jitter. The PCM1793 provides balanced voltage outputs, allowing the user to optimize analog performance externally. Sampling rates up to 200 kHz are supported.
评论(0)
发评论
下载排行榜
