SN74ALVC126,pdf(QUADRUPLE BUS
消耗积分:3 | 格式:rar | 大小:395 | 2010-07-16
张强
分享资料个
This quadruple bus buffer gate is designed for 1.65-V to 3.6-V VCC operation.
The SN74ALVC126 features independent line drivers with 3-state outputs. Each output is disabled when the associated output-enable (OE) input is low.
To ensure the high-impedance state during power up or power down, OE should be tied to GND through a pulldown resistor; the minimum value of the resistor is determined by the current-sourcing capability of the driver.
评论(0)
发评论
下载排行榜
