SN54ABT16470,SN74ABT16470,pdf(
消耗积分:2 | 格式:rar | 大小:332 | 2010-07-21
分享资料个
The 'ABT16470 are 16-bit registered transceivers that contain two sets of D-type flip-flops for temporary storage of data flowing in either direction. The 'ABT16470 can be used as two 8-bit transceivers or one 16-bit transceiver. Separate clock (CLKAB or CLKBA) and output-enable (OEAB\ or OEBA\) inputs are provided for each register to permit independent control in either direction of data flow.
To avoid false clocking of the flip-flops, clock enable (CLKEN\) should not be switched from high to low while CLK is high.
To ensure the high-impedance state during power up or power down, OE\ should be tied to VCC through a pullup resistor; the minimum value of the resistor is determined by the current-sinking capability of the driver.
评论(0)
发评论
下载排行榜
