SN54ALS29821,SN74ALS29821,pdf(
消耗积分:2 | 格式:rar | 大小:283 | 2010-07-26
久醉不醒
分享资料个
These 10-bit edge-triggered D-type flip-flops feature 3-state outputs designed specifically for driving highly capacitive or relatively low-impedance loads. These devices are particularly suitable for implementing wider buffer registers, I/O ports, bidirectional bus drivers with parity, and working registers.
On the positive transition of the clock (CLK) input, the Q outputs are true to the data (D) input.
A buffered output-enable () input can place the ten outputs in either a normal logic state (high or low logic levels) or a high-impedance state. The outputs also are in the high-impedance state during power-up and power-down conditions. The outputs remain in the high-impedance state while the device is powered down.
评论(0)
发评论
下载排行榜
