SN74HC273-Q1,pdf(Octal D-Type
消耗积分:3 | 格式:rar | 大小:206 | 2010-07-29
刘埃生
分享资料个
This circuit is a positive-edge-triggered D-type flip-flop with a direct clear (CLR) input.
Information at the data (D) inputs meeting the setup time requirements is transferred to the Q outputs on the positive-going edge of the clock (CLK) pulse. Clock triggering occurs at a particular voltage level and is not related directly to the transition time of the positive-going pulse. When CLK is at either the high or low level, the D input has no effect at the output.
评论(0)
发评论
下载排行榜
