SN54HC594,SN74HC594,pdf(8-BIT
消耗积分:3 | 格式:rar | 大小:680 | 2010-08-03
分享资料个
The ’HC594 devices contain an 8-bit serial-in, parallel-out shift register that feeds an 8-bit D-type storage register. Separate clocks and direct overriding clear (RCLR\, SRCLR\) inputs are provided on both the shift and storage registers. A serial (QH’) output is provided for cascading purposes.
Both the shift register (SRCLK) and storage register (RCLK) clocks are positive edge triggered. If both clocks are connected together, the shift register always is one count pulse ahead of the storage register.
The parallel (QA–QH) outputs have high-current capability. QH’ is a standard output
评论(0)
发评论
下载排行榜
