TPS22924C,pdf(Ultra-Low ON-Res
消耗积分:5 | 格式:rar | 大小:1324 | 2010-08-22
overheat
分享资料个
The TPS22924C is a small, ultra-low rON load switch with controlled turn on. The devices contain N-channel MOSFETs that can operate over an input voltage range of 0.75 V to 3.6 V. An integrated charge pump biases the NMOS switch to achieve a minimum switch ON resistance. The switch is controlled by an on/off input (ON), which is capable of interfacing directly with low-voltage control signals.
A 1250- on-chip load resistor is added for output quick discharge when switch is turned off. The rise time of the device is internally controlled to avoid inrush current. The TPS22924C features a rise time of 800 µs at 3.6 V.
The TPS22924C is available in an ultra-small space-saving 6-pin CSP package and is characterized for operation over the free-air temperature range of –40ºC to 85ºC.
评论(0)
发评论
下载排行榜
