TPD4E004,pdf(4-Channel ESD-Pro
消耗积分:5 | 格式:rar | 大小:179 | 2010-08-25
好名字
分享资料个
The TPD4E004 is a low-capacitance ±15-kV ESD-protection diode array designed to protect sensitive electronics attached to communication lines. Each channel consists of a pair of diodes that steers ESD current pulses to VCC or GND. The TPD4E004 protects against ESD pulses up to ±15-kV Human-Body Model (HBM), ±8-kV Contact Discharge, and ±12-kV Air-Gap Discharge, as specified in IEC 61000-4-2. This device has a 1.6-pF capacitance per channel, making it ideal for use in high-speed data IO interfaces.
The TPD4E004 is a quad-ESD structure designed for USB, ethernet, and other high-speed applications.
The TPD4E004 is available in the DRY package and is specified for -40°C to 85°C operation.
评论(0)
发评论
下载排行榜
