ONET8501PB,pdf(11.3-Gbps Rate-
消耗积分:5 | 格式:rar | 大小:970 | 2010-08-28
分享资料个
The ONET8501PB is a high-speed, 3.3-V limiting amplifier for multiple fiber optic and copper cable applications with data rates from 2 Gbps up to 11.3 Gbps.
The device provides a two-wire serial interface which allows digital control of the bandwidth, output amplitude, output pre-emphasis, input threshold voltage (slice level) and the loss of signal assert level. Predetermined settings for bandwidth and LOS assert levels can also be selected with external rate selection pins.
The ONET8501PB provides a gain of about 34dB which ensures a fully differential output swing for input signals as low as 20mVp-p. The output amplitude can be adjusted to 350mVpp, 650mVpp, or 850mVpp. To compensate for frequency dependent loss of microstrips or striplines connected to the output of the device, programmable pre-emphasis is included in the output stage.
评论(0)
发评论
下载排行榜
