The EL5156, EL5157, EL5256, and EL5257 are 600MHz bandwidth -3dB voltage mode feedback amplifiers with DC accuracy of <0.01%, 1mV offsets and 40kV/V open loop gains. These amplifiers are ideally suited for applications ranging from precision measurement instrumentation to high speed video and monitor applications demanding the very highest linearity at very high frequency. Capable of operating with as little as 6.0mA of current from a single supply ranging from 5V to 12V and dual supplies ranging from ±2.5V to ±5.0V, these amplifiers are also well suited for handheld, portable and battery-powered equipment. With their capability to output as much as 140mA, any member of this family is comfortable with demanding load conditions.
Single amplifiers are available in SOT-23 packages and duals in a 10 Ld MSOP package for applications where board space is critical. Additionally, singles and duals are available in the industry-standard 8 Ld SOIC package. All parts operate over the industrial temperature range of -40°C to +85°C.
Key Features
Features
600MHz -3dB bandwidth, 240MHz 0.1dB bandwidth
700V/μs slew rate
<1mV input offset
Very high open loop gains 92dB
Low supply current = 6mA
140mA output current
Single supplies from 5V to 12V
Dual supplies from ±2.5V to ±5V
Fast disable on the EL5156 and EL5256
Low cost
Pb-free available (RoHS compliant)
