LM239A-Q1,pdf(Quad Differentia
消耗积分:3 | 格式:rar | 大小:185 | 2010-09-23
分享资料个
This device consists of four independent voltage comparators that are designed to operate from a single power supply over a wide range of voltages. Operation from dual supplies also is possible as long as the difference between the two supplies is 2 V to 36 V, and VCC is at least 1.5 V more positive than the input common-mode voltage. Current drain is independent of the supply voltage. The outputs can be connected to other open-collector outputs to achieve wired-AND relationships.
评论(0)
发评论
下载排行榜
