TPS62060,pdf(3-MHz 1.6A Step-D
消耗积分:3 | 格式:rar | 大小:1102 | 2010-10-03
分享资料个
The TPS62060 is a highly efficient synchronous step-down DC-DC converter and provides up to 1.6A output current.
With an input voltage range of 2.7V to 6V the device is a perfect fit for power conversion from a single Li-Ion battery as well from 5V or 3.3V system supply rails. The TPS62060 operates at 3-MHz fixed frequency and enters Power Save Mode operation at light load currents to maintain high efficiency over the entire load current range. The Power Save Mode is optimized for low output voltage ripple. For low noise applications, the device can be forced into fixed frequency PWM mode by pulling the MODE pin high.
In the shutdown mode, the current consumption is reduced to less than 1µA and an internal circuit discharges the output capacitor.
评论(0)
发评论
下载排行榜
