REG113-33,pdf(DMOS 400mA Low-D
消耗积分:2 | 格式:rar | 大小:531 | 2010-10-14
分享资料个
The REG113 is a family of low-noise, low-dropout linear regulators with low ground pin current. Its new DMOS topology provides significant improvement over previous designs, including low-dropout voltage (only 250mV typ at full load), and better transient performance. In addition, no output capacitor is required for stability, unlike conventional low-dropout regulators that are difficult to compensate and require expensive low ESR capacitors greater than 1µF.
Typical ground pin current is only 850µA (at IOUT = 400mA) and drops to 10nA when not enabled. Unlike regulators with PNP pass devices, quiescent current remains relatively constant over load variations and under dropout conditions.
The REG113 has very low output noise (typically 28µVrms for VOUT = 3.
评论(0)
发评论
下载排行榜
