TLC59025,pdf(Low-Power 16-Chan
消耗积分:2 | 格式:rar | 大小:616 | 2010-11-02
韩刚龙
分享资料个
特性
  • 16 Constant-Current Output Channels
  • Matches Industry Standard IOUT to External Resistor Ratio
  • Constant Output Current Invariant to Load Voltage Change
  • Excellent Output Current Accuracy:
    • Between Channels: < ±5% (Max)
    • Between ICs: < ±6% (Max)
  • Constant Output Current Range:
    3 mA to 45 mA
  • Output Current Adjusted By External Resistor
  • Fast Response of Output Current, OE (Min): 100 ns
  • 30-MHz Clock Frequency
  • Schmitt-Trigger Inputs
  • 3.3-V to 5-V Supply Voltage
  • Thermal Shutdown for Overtemperature Protection
  • ESD Performance: 1-kV HBM
  • APPLICATIONS
    • Gaming Machine/Entertainment
    • General LED Applications
    • LED Display Systems
    • Signs LED Lighting
    • White Goods
评论(0)
发评论
下载排行榜
