BQ26500,pdf(Single Cell Li-Ion
消耗积分:3 | 格式:rar | 大小:556 | 2010-11-05
分享资料个
The bq26500, the first in the bqJUNIOR™ family of advanced gas gauge device for handheld applications, is a highly accurate standalone single-cell Li-Ion and Li-Pol battery capacity monitoring and reporting device targeted at space limited portable applications. The device monitors a voltage drop across a small current sense resistor connected in series with the battery to determine charge and discharge activity of the battery. Compensations for battery temperature, self-discharge, and rate of discharge are applied to the charge counter to provide available capacity across a wide range of operating conditions. Battery capacity is automatically recalibrated, or learned, in the course of a discharge cycle from full to empty.
评论(1)
发评论
manbuyunduanjh 2015-03-17
0 回复 举报
看看 收起回复
下载排行榜
全部1条评论
