基于MAX16024的低功耗设备电源备份方案
消耗积分:5 | 格式:rar | 大小:586 | 2010-12-27
王秀兰
分享资料个
 针对低功耗设备对电源供电稳定性的严格需求,提出利用Maxim公司推出的MAX16024实现电源备份方案。简要介绍MAX16024器件的功能及其内部结构,给出一个在MAX16024的基础上所构建的电源备份系统应用实例。经实验证明,该方案电路工作稳定,并在低功耗设备中具有良好的供电稳定性。
Abstract:
 Aiming at the supply stability requirement for low-power devices,a battery-backup scheme based on MAX16024which is produced by Maxim is proposed in this paper.The function and structure of MAX16024are introduced,and an application example of battery-backup circuit based on MAX16024is provided.The experimental results prove that the scheme circuit works stably,and has good stability for power supply in the low-power devices.
评论(0)
发评论
下载排行榜
