PCM61/PCM61P pdf datasheet (Se
消耗积分:5 | 格式:rar | 大小:333 | 2008-12-18
分享资料个
The PCM61P is an 18-bit totally pin compatible performance
replacement for the popular 16-bit PCM56P.
With the addition of two extra bits, lower max THD+N
(–92dB; PCM61P-K) can be achieved in audio applications
already using the PCM56P. The PCM61P is
complete with internal reference and output op amp and
requires no external parts to function as an 18-bit DAC.
The PCM61P is capable of an 8-times oversampling
rate (single channel) and meets all of its specifications
without an external output deglitcher.
The PCM61P comes in a small, reliable 16-pin plastic
DIP package that has passed operating life tests under
simultaneous high temperature, high humidity and high
pressure testing.
评论(0)
发评论
下载排行榜
