The EL5624A integrates six gamma reference buffers with a single high power VCOM amplifier. Each gamma buffer has a bandwidth of 12MHz and features a slew rate of 15V/μs. The output current is rated at 30mA continuous, 140mA peak. The VCOM amplifier is rated for 260mA peak output current and also features higher slew rate (70V/μs) and bandwidth (35MHz) for use in error cancellation circuits. The EL5624A is available in the 20-pin HTSSOP package and is specified for operation over the -40°C to +85°C temperature range.
