EL5251, EL5451 pdf datasheet (
消耗积分:3 | 格式:rar | 大小:443 | 2009-01-16
分享资料个
The EL5150, EL5151, EL5250, EL5251, and EL5451 are
200MHz bandwidth -3dB voltage mode feedback amplifiers
with DC accuracy of 0.01%, 1mV offsets and 10kV/V open
loop gains. These amplifiers are ideally suited for applications
ranging from precision measurement instrumentation to high
speed video and monitor applications. Capable of operating
with as little as 1.4mA of current from a single supply ranging
from 5V to 12V, dual supplies ranging from ±2.5V to ±5.0V,
these amplifiers are also well suited for handheld, portable
and battery-powered equipment.
Single amplifiers are offered in SOT-23 packages and duals in
a 10 Ld MSOP package for applications where board space is
critical. Quad amplifiers are available in a 14 Ld SOIC
package. Additionally, singles and duals are available in the
industry-standard 8 Ld SOIC package. All parts operate over
the industrial temperature range of -40°C to +85°C.
评论(0)
发评论
下载排行榜
