EL6245 pdf datasheet (3-Channe
消耗积分:3 | 格式:rar | 大小:436 | 2009-01-16
王飞云
分享资料个
The EL6244 is a high-performance
three channel laser driver that provides
controlled current to a grounded laser
diode. Channels 2 and 3 should be used as the write
channels, with switching speeds of approximately one
nanosecond rise/fall time. All three channels are summed
together at the IOUT output, allowing the user to create
multilevel waveforms in order to optimize laser diode
performance. The level of the output current is set by an
analog voltage applied to an external resistor which converts
the voltage into a current at the IIN pin (virtually ground). The
current seen at this pin is then amplified to become a current
source at pin IOUT.
An on-chip 500MHz oscillator is provided to allow output
current modulation when in any mode. This is turned on only
when the OSCEN and OUTEN pins are held high. Complete
control of amplitude and frequency is set by two external
resistors connected to ground at pins RFREQ and RAMP
(see graphs in this data sheet for further explanation).
评论(0)
发评论
下载排行榜
