EL5246, EL5444 pdf datasheet (
消耗积分:2 | 格式:rar | 大小:444 | 2009-01-16
分享资料个
The EL5144 series amplifiers are voltage-feedback, high
speed, rail-to-rail amplifiers designed to operate on a single
+5V supply. They offer unity gain stability with an unloaded -
3dB bandwidth of 100MHz. The input common-mode voltage
range extends from the negative rail to within 1.5V of the
positive rail. Driving a 75Ω double terminated coaxial cable,
the EL5144 series amplifiers drive to within 150mV of either
rail. The 200V/μs slew rate and 0.1%/0.1° differential
gain/differential phase makes these parts ideal for composite
and component video applications. With their voltagefeedback
architecture, these amplifiers can accept reactive
feedback networks, allowing them to be used in analog
filtering applications These amplifiers will source 90mA and
sink 65mA.
The EL5146 and EL5246 have a power-savings disable
feature. Applying a standard TTL low logic level to the CE
(Chip Enable) pin reduces the supply current to 2.6μA within
10ns. Turn-on time is 500ns, allowing true break-beforemake
conditions for multiplexing applications. Allowing the
CE pin to float or applying a high logic level will enable the
amplifier.
评论(0)
发评论
下载排行榜
