ISL8105/ISL8105B pdf datasheet
消耗积分:5 | 格式:rar | 大小:666 | 2009-03-05
分享资料个
The ISL8105B is a simple single-phase PWM controller for a
synchronous buck converter. It operates from +5V or +12V bias
supply voltage. With integrated linear regulator, boot diode, and
N-Channel MOSFET gate drivers, the ISL8105B reduces
external component count and board space requirements.
These make the IC suitable for a wide range of applications.
Utilizing voltage-mode control, the output voltage can be
precisely regulated to as low as 0.6V. The 0.6V internal
reference features a maximum tolerance of ±1.0% over the
commercial temperature range, and ±1.5% over the
industrial temperature range. The controller operates with a
fixed switching frequency of 300kHz.
评论(0)
发评论
下载排行榜
