MIC2605/MIC2606 pdf datasheet
消耗积分:5 | 格式:rar | 大小:444 | 2009-03-18
申换换
分享资料个
The MIC2605/6 is a 1.2MHz/2MHz, PWM DC/DC boost switching regulator available in a 2mm x 2mm MLF ® package. High power density is achieved with the MIC2605/6’s internal 40V/0.5A switch and schottky diode, allowing it to power large loads in a tiny footprint.
The MIC2605/6 implements constant frequency 1.2MHz/2MHz PWM current mode control. The MIC2605/6 offers internal compensation that offers excellent transient response and output regulation performance. The high frequency operation saves board space by allowing small, low-profile external components. The fixed frequency PWM scheme also reduces spurious switching noise and ripple to the input power source.
The MIC2605/6 is available in an 8-pin 2mm x 2mm MLF ® leadless package. This package has an output over-voltage protection feature.
The MIC2605/6 has an operating junction temperature range of –40 °C to +125 °C.
评论(0)
发评论
下载排行榜
