MAX14541/MAX14541E,pdf,datashe
消耗积分:5 | 格式:rar | 大小:422 | 2009-05-31
李静
分享资料个
The MAX14541E low-capacitance ±15kV ESD-protection diode array is designed to protect sensitive electronics attached to communication lines. Each channel consists of a pair of diodes that steer ESD current pulses to VCC or GND.
The MAX14541E protects against ESD pulses up to ±15kV Human Body Model (HBM) and ±15kV Air-Gap Discharge, as specified in IEC 61000-4-2. The device has a 6pF (typ) on-capacitance per channel, making them ideal for use on high-speed data I/O interfaces.
The MAX14541E is a triple I/O protector designed for biometric connectors, portable connectors, and SVGA video connections with ultra-low leakage current.
The device is available in a 5-pin SC70 package and is specified over the -40°C to +125°C automotive operating temperature range.
评论(0)
发评论
下载排行榜
