MAX187,MAX189低功耗、12位串行ADC数据资料
消耗积分:0 | 格式:pdf | 大小:508 KB | 2012-10-17
分享资料个
The MAX187/MAX189 serial 12-bit analog-to-digital converters(ADCs) operate from a single +5V supply andaccept a 0 to 5V analog input. Both parts feature an 8.5Fssuccessive-approximation ADC, a fast track/hold (1.5Fs),an on-chip clock, and a high-speed 3-wire serial interface.The MAX187/MAX189 digitize signals at a 75kspsthroughput rate. An external clock accesses data fromthe interface, which communicates without externalhardware to most digital signal processors and microcontrollers.The interface is compatible with SPI, QSPIK,and MICROWIREM.
评论(1)
发评论
刘宇杰 2012-12-21
0 回复 举报
不错的资料,很全面 收起回复
下载排行榜
全部1条评论
