MAX16961,pdf数据手册
消耗积分:0 | 格式:pdf | 大小:612 KB | 2013-01-07
分享资料个
The MAX16961 is a high-efficiency, synchronous stepdownconverter that operates with a 2.7V to 5.5V inputvoltage range and provides a 0.8V to 3.6V output voltagerange. The wide input/output voltage range and the abilityto provide up to 3A to load current make this deviceideal for on-board point-of-load and post-regulationapplications. The device achieves -3.7%/+2.6% outputerror over load, line, and temperature ranges.
评论(0)
发评论
下载排行榜
