全英版述说TPS40210电源芯片
消耗积分:2 | 格式:pdf | 大小:1394KB | 2014-08-11
873981459
分享资料个
The TPS40210 and TPS40211 are wide-input voltage (4.5 V to 52 V), non-synchronous boost controllers。They are suitable for topologies which require a grounded source N-channel FET including boost,flyback,SEPIC and various LED Driver applications。The device features include programmable soft start,overcurrent protection with automatic retry and programmable oscillator frequency。 Current mode control provides improved transient response and simplified loop compensation。 The main difference between the two parts is the reference voltage to which the error amplifier regulates the FB pin。
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
