LM3876/LM3876t/LM3876tf,pdf da
消耗积分:10 | 格式:rar | 大小:433 | 2009-08-19
孙成红
分享资料个
The LM3876 is a high-performance audio power amplifier capable of delivering 56W of continuous average power to an 8Ω load with 0.1% THD+N from 20Hz–20kHz.
The performance of the LM3876, utilizing its Self Peak Instantaneous
Temperature (°Ke) (SPiKe™) protection circuitry,
puts it in a class above discrete and hybrid amplifiers
by providing an inherently, dynamically protected Safe Operating
Area (SOA). SPiKe protection means that these
parts are completely safeguarded at the output against overvoltage,
undervoltage, overloads, including shorts to the
supplies, thermal runaway, and instantaneous temperature
peaks.
The LM3876 maintains an excellent signal-to-noise ratio of
greater than 95dB (min) with a typical low noise floor of
2.0μV. It exhibits extremely low THD+N values of 0.06% at
the rated output into the rated load over the audio spectrum,
and provides excellent linearity with an IMD (SMPTE) typical rating of 0.004%.
评论(0)
发评论
下载排行榜
