2N2223 pdf datasheet
消耗积分:5 | 格式:rar | 大小:333 | 2008-07-08
小组店小二
分享资料个
Dual Transistors
TO-78 Case
PD @ TA=25o
C=600mW Total (Both Die Equal Power)
TYPE NO. DESCRIPTION I
C VCBO VCEO hFE @ I
C
@ VCE VCE
(SAT) @  I
C fT MATCHING
(mA) (V) (V) (V) (mA) (V) (V) (mA) (MHz) hFE VBE
*TYP
MAX MIN MIN MIN MAX MAX MIN % (mV)
2N2060 NPN AMPL/SWITCH 500 100 60 50 150 10 5.0 1.2 50 60 10 5.0
2N2060A NPN AMPL/SWITCH 500 100 60 50 150 10 5.0 0.6 50 60 10 3.0
2N2223 NPN AMPL/SWITCH 500 100 60 50 200 10 5.0 1.2 50 50 20 15
2N2223A NPN AMPL/SWITCH 500 100 60 50 200 10 5.0 1.2 50 50 10 5.0
2N2453 NPN LOW NOISE 50 60 30 150 600 1.0 5.0 1.0 5.0 60 10 3.0
2N2453A NPN LOW NOISE 50 80 50 150 600 1.0 5.0 1.0 5.0 60 10 3.0
2N2480 NPN AMPL/SWITCH 500 75 35 30 350 1.0 5.0 1.3 50 50 20 10
2N2480A NPN AMPL/SWITCH 500 80 40 50 200 1.0 5.0 1.2 50 50 20 5.0
2N2639 NPN LOW NOISE 30 45 45 50 300 0.01 5.0 1.0 10 40 10 5.0
2N2640 NPN LOW NOISE 30 45 45 50 300 0.01 5.0 1.0 10 40 20 10
2N2641 NPN LOW NOISE 30 45 45 50 300 0.01 5.0 1.0 10 40 - - - -
2N2642 NPN LOW NOISE 30 45 45 100 300 0.01 5.0 1.0 10 40 10 5.0
2N2643 NPN LOW NOISE 30 45 45 100 300 0.01 5.0 1.0 10 40 20 10
2N2644 NPN LOW NOISE 30 45 45 100 300 0.01 5.0 1.0 10 40 - - - -
2N2652 NPN AMPL/SWITCH 500 100 60 50 200 1.0 5.0 1.2 50 60 15 3.0
2N2652A NPN AMPL/SWITCH 500 100 60 50 200 1.0 5.0 1.2 50 60 10 3.0
2N2722 NPN LOW NOISE 40 45 45 50 250 0.001 5.0 1.0 10 100 10 5.0
2N2903 NPN LOW NOISE 50 60 30 125 625 1.0 5.0 1.0 5.0 60 20 10
2N2903A NPN LOW NOISE 50 60 30 125 625 1.0 5.0 1.0 5.0 60 10 5.0
2N2913 NPN LOW NOISE 30 45 45 60 240 0.01 5.0 0.35 1.0 60 - - - -
2N2914 NPN LOW NOISE 30 45 45 150 600 0.01 5.0 0.35 1.0 60 - - - -
2N2915 NPN LOW NOISE 30 45 45 60 240 0.01 5.0 0.35 1.0 60 10 3.0
2N2915A NPN LOW NOISE 30 45 45 60 240 0.01 5.0 0.35 1.0 60 10 1.5
2N2916 NPN LOW NOISE 30 45 45 150 600 0.01 5.0 0.35 1.0 60 10 3.0
2N2916A NPN LOW NOISE 30 45 45 150 600 0.01 5.0 0.35 1.0 60 10 1.5
2N2917 NPN LOW NOISE 30 45 45 60 240 0.01 5.0 0.35 1.0 60 20 5.0
2N2918 NPN LOW NOISE 30 45 45 150 600 0.01 5.0 0.35 1.0 60 20 5.0
2N2919 NPN LOW NOISE 30 60 60 60 240 0.01 5.0 0.35 1.0 60 10 3.0
2N2919A NPN LOW NOISE 30 60 60 60 240 0.01 5.0 0.35 1.0 60 10 1.5
2N2920 NPN LOW NOISE 30 60 60 150 600 0.01 5.0 0.35 1.0 60 10 3.0
2N2920A NPN LOW NOISE 30 60 60 150 600 0.01 5.0 0.35 1.0 60 10 1.5
2N3726 PNP LOW NOISE 300 45 45 135 350 1.0 5.0 0.25 50 200 10 5.0
2N3727 PNP LOW NOISE 300 45 45 135 350 1.0 5.0 0.25 50 200 10 2.5
2N3806 PNP LOW NOISE 50 60 60 150 450 1.0 5.0 0.2 0.1 100 - - - -
2N3807 PNP LOW NOISE 50 60 60 300 900 1.0 5.0 0.2 0.1 100 - - - -
2N3808 PNP LOW NOISE 50 60 60 150 450 1.0 5.0 0.2 0.1 100 20 5.0
2N3809 PNP LOW NOISE 50 60 60 300 900 1.0 5.0 0.2 0.1 100 20 5.0
2N3810 PNP LOW NOISE 50 60 60 150 450 1.0 5.0 0.2 0.1 100 10 3.0
2N3810A PNP LOW NOISE 50 60 60 150 450 1.0 5.0 0.2 0.1 100 5.0 1.5
2N3811 PNP LOW NOISE 50 60 60 300 900 1.0 5.0 0.2 0.1 100 10 3.0
2N3811A PNP LOW NOISE 50 60 60 300 900 1.0 5.0 0.2 0.1 100 5.0 1.5
2N4015 PNP AMPL/SWITCH 300 60 60 135 350 1.0 5.0 0.25 50 200 10 5.0
2N4016 PNP AMPL/SWITCH 300 60 60 135 350 1.0 5.0 0.25 50 200 10 2.5
2N5794 NPN AMPL/SWITCH 600 75 40 100 300 150 10 0.3 150 250 - - - -
2N5796 PNP AMPL/SWITCH 600 60 60 100 300 150 10 0.4 150 200 - - - -
MD708 NPN SAT SWITCH 200 40 15 40 200 10 1.0 0.5 100 300 - - - -
MD708A NPN SAT SWITCH 200 40 15 40 200 10 1.0 0.5 100 300 10 5.0
MD708B NPN SAT SWITCH 200 40 15 40 200 10 1.0 0.5 100 300 20 10
评论(0)
发评论
下载排行榜
