LM20123,pdf datasheet (Synchro
消耗积分:3 | 格式:rar | 大小:551 | 2009-09-28
479461
分享资料个
The LM20123 is a full featured 1.5 MHz synchronous buck
regulator capable of delivering up to 3A of continuous output
current. The current mode control loop can be compensated
to be stable with virtually any type of output capacitor. For
most cases, compensating the device only requires two external
components, providing maximum flexibility and ease of
use. The device is optimized to work over the input voltage
range of 2.95V to 5.5V making it suited for a wide variety of
low voltage systems.
评论(0)
发评论
下载排行榜
