LM2717-ADJ,pdf datasheet (Dual
消耗积分:3 | 格式:rar | 大小:554 | 2009-10-06
郑成枝
分享资料个
The LM2717-ADJ is composed of two PWM DC/DC buck
(step-down) converters. Both converters are used to generate
an adjustable output voltage as low as 1.267V. Both also feature
low RDSON (0.16Ω) internal switches for maximum efficiency.
Operating frequency can be adjusted anywhere
between 300kHz and 600kHz allowing the use of small external
components. External soft-start pins for each converter
enables the user to tailor the soft-start times to a specific application.
Each converter may also be shut down independently
with its own shutdown pin. The LM2717-ADJ is
available in a low profile 24-lead TSSOP package ensuring a
low profile overall solution.
评论(0)
发评论
下载排行榜
