LB1836M-TLM-E低饱和双向电机驱动低电压驱动
消耗积分:0 | 格式:pdf | 大小:114KB | 2017-10-31
一路而去西天取经
分享资料个
电机驱动
  Overview The LB1836M is a low-saturation two-channel bidirectional motor driver IC for use in low-voltage applications. The LB1836M is a bipolar stepper-motor driver IC that is ideal for use in printers, FDDs, cameras and other portable devices.
  Features
  • Low voltage operation (2.5V min)
  • Low saturation voltage (upper transistor + lower transistor residual voltage ; 0.40V typ at 400mA)。
  • Parallel connection (Upper transistor + lower transistor residual voltage ; 0.5V typ at 800mA)。
  • Separate logic power supply and motor power supply • Brake function
  • Spark killer diodes built in • Thermal shutdown circuit built in
  • Compact package (14-pin MFP)
评论(0)
发评论
下载排行榜
