ICS9DB102 pdf datasheet (2 Out
消耗积分:5 | 格式:rar | 大小:343 | 2008-08-06
韩刚龙
分享资料个
The ICS9DB102 zero-delay buffer supports PCI Express clocking requirements. The ICS9DB102 is driven by a differential
SRC output pair from an ICS CK409/CK410-compliant main clock generator such as the ICS952601 or ICS954101. It
attenuates jitter on the input clock and has a selectable PLL Band Width to maximize performance in systems with or without
Spread-Spectrum clocking. An SMBus interface allows control of the PLL bandwidth and bypass options, while 2 clock
request (OE#) pins make the ICS9DB102 suitable for Express Card applications.
评论(0)
发评论
下载排行榜
