TPS51200 pdf datasheet (吸入/输出D
消耗积分:5 | 格式:rar | 大小:999 | 2008-08-07
417804
分享资料个
The TPS51200 is a sink/source Double Data Rate (DDR) termination regulator specifically designed for low input voltage, low-cost, low-noise systems where space is a key consideration.
The TPS51200 maintains a fast transient response and only requires a minimum output capacitance of 20 µF. The TPS51200 supports a remote sensing function and all power requirements for DDR, DDR2, DDR3, and Low Power DDR3/DDR4 VTT bus termination.
In addition, the TPS51200 provides an open-drain PGOOD signal to monitor the output regulation and an EN signal that can be used to discharge VTT during S3 (suspend to RAM) for DDR applications.
The TPS51200 is available in the thermally-efficient SON-10 PowerPAD package, and is rated both Green and Pb-free. It is specified from –40°C to +85°C.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
