LTC3616,pdf,datasheet,Synchron
消耗积分:5 | 格式:rar | 大小:344 | 2010-03-21
丁冬芹
分享资料个
The LTC3616 is a low quiescent current monolithic synchronous
buck regulator using a current mode, constant
frequency architecture. The no-load DC supply current
in sleep mode is only 70μA while maintaining the output
voltage (Burst Mode operation) at no load, dropping to zero
current in shutdown. The 2.25V to 5.5V input supply voltage
range makes the LTC3616 ideally suited for single Li-Ion
as well as fixed low voltage input applications. 100% duty
cycle capability provides low dropout operation, extending
the operating time in battery-powered systems.
评论(0)
发评论
下载排行榜
