NCP1351 pdf,detasheet
Variable Off Time PWM Controller
The NCP1351 is a current-mode controller targeting low power
off-line flyback Switched Mode Power Supplies (SMPS) where cost
is of utmost importance. Based on a fixed peak current technique
(quasi-fixed TON), the controller decreases its switching frequency as
the load becomes lighter. As a result, a power supply using the
NCP1351 naturally offers excellent no-load power consumption,
while optimizing the efficiency in other loading conditions. When the
frequency decreases, the peak current is gradually reduced down to
approximately 30% of the maximum peak current to prevent
transformer mechanical resonance.
下载资料需要登录,并消耗一定积分。
全部1条评论
