ADS61B29/ADS61B49,pdf (14-/12-
消耗积分:2 | 格式:rar | 大小:1755 | 2010-06-04
vinww特烦恼
分享资料个
The ADS61B49 (ADS61B29) is a 14-bit (12-bit) A/D  converter with a sampling rate up to 250 MSPS. It  combines high dynamic performance and low power  consumption in a compact 48-QFN package. An   integrated analog buffer makes it well-suited for  multi-carrier, wide  bandwidth communications  applications. The buffer maintains constant  performance and input impedance across a wide  frequency range.
评论(0)
发评论
下载排行榜
