ADS5422,pdf (14-Bit, 62MSPS Sa
消耗积分:3 | 格式:rar | 大小:573 | 2010-06-04
h1708587244.0670
分享资料个
The ADS5422 is a high-dynamic range, 14-bit, 62MSPS, pipelined Analog-to-Digital Converter (ADC). It includes a high-bandwidth linear track-and-hold amplifier that gives good spurious performance up to the Nyquist rate. The clock input can accept a low-level differential sine wave or square wave signal down to 0.5VPP, further improving the Signal-to-Noise Ratio (SNR) performance.
The ADS5422 has a 4VPP differential input range (2VPP • 2 inputs) for optimum Spurious-Free Dynamic Range (SFDR). The differential operation gives the lowest even-order harmonic components. A lower input voltage can also be selected using the internal references, further optimizing SFDR.
The ADS5422 is available in an LQFP-64 package.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
