AT91M63200 ARM® Thumb®
消耗积分:2 | 格式:rar | 大小:2048 | 2010-07-01
罗星
分享资料个
Description
The AT91M63200 is a member of the Atmel AT91 16/32-bit Microcontroller family,
which is based on the ARM7TDMI processor core.
This processor has a high-performance 32-bit RISC architecture with a high-density
16-bit instruction set and very low power consumption. In addition, a large number of
internally banked registers result in very fast exception handling, making the device
ideal for real-time control applications. The AT91 ARM-based MCU family also fea-
tures Atmel’s high-density, in-system programmable, nonvolatile memory technology.
The AT91M63200 has a direct connection to off-chip memory, including Flash,
through the External Bus Interface.
The Multi-processor Interface (MPI) provides a high-performance interface with an
external co-processor or a high-bandwidth peripheral.
The AT91M63200 is manufactured using Atmel’s high-density CMOS technology. By
combining the ARM7TDMI microcontroller core with on-chip SRAM, a multi-processor
interface and a wide range of peripheral functions on a monolithic chip, the
AT91M63200 provides a highly-flexible and cost-effective solution to many compute-
intensive multi-processor applications.
评论(0)
发评论
下载排行榜
