SN74ALVCH16827,pdf(20-BIT BUFF
消耗积分:2 | 格式:rar | 大小:338 | 2010-07-16
绝代双骄
分享资料个
This 20-bit noninverting buffer/driver is designed for 1.65-V to 3.6-V VCC operation.
The SN74ALVCH16827 is composed of two 10-bit sections with separate output-enable signals. For either 10-bit buffer section, the two output-enable (1OE1\ and 1OE2\ or 2OE1\ and 2OE2\) inputs must both be low for the corresponding Y outputs to be active. If either output-enable input is high, the outputs of that 10-bit buffer section are in the high-impedance state.
To ensure the high-impedance state during power up or power down, OE\ should be tied to VCC through a pullup resistor; the minimum value of the resistor is determined by the current-sinking capability of the driver.
Active bus-hold circuitry is provided to hold unused or floating data inputs at a valid logic level.
评论(0)
发评论
下载排行榜
