LM120/LM320 pdf,LM120/LM320 da
消耗积分:5 | 格式:rar | 大小:555 | 2008-09-06
分享资料个
LM120/LM320 Series 3-Terminal Negative Regulators
General Description
The LM120 series are three-terminal negative regulators with
a fixed output voltage of −5V, −12V, and −15V, and up to 1.5A
load current capability. Where other voltages are required, the
LM137 and LM137HV series provide an output voltage range
of −1.2V to −47V.
The LM120 need only one external component—a compensation
capacitor at the output, making them easy to apply.
Worst case guarantees on output voltage deviation due to any
combination of line, load or temperature variation assure satisfactory
system operation.
Exceptional effort has been made to make the LM120 Series
immune to overload conditions. The regulators have current
limiting which is independent of temperature, combined with
thermal overload protection. Internal current limiting protects
against momentary faults while thermal shutdown prevents
junction temperatures from exceeding safe limits during prolonged
overloads.
Although primarily intended for fixed output voltage applications,
the LM120 Series may be programmed for higher output
voltages with a simple resistive divider. The low quiescent
drain current of the devices allows this technique to be used
with good regulation.
评论(0)
发评论
下载排行榜
