SN54BCT245,SN74BCT245,pdf(Octa
消耗积分:3 | 格式:rar | 大小:722 | 2010-07-24
分享资料个
These octal bus transceivers are designed for asynchronous communication between data buses. The devices transmit data from the A bus to the B bus or from the B bus to the A bus, depending upon the level at the direction-control (DIR) input. The output-enable (OE)\ input can be used to disable the device so the buses are effectively isolated.
评论(0)
发评论
下载排行榜
