SN74F175,pdf(Quadruple D-Type
消耗积分:3 | 格式:rar | 大小:481 | 2010-07-29
杨海清
分享资料个
This positive-edge-triggered flip-flop utilizes TTL circuitry to implement D-type flip-flop logic with a direct clear (CLR)\ input. Information at the data (D) inputs meeting setup-time requirements is transferred to outputs on the positive-going edge of the clock pulse. Clock triggering occurs at a particular voltage level and is not directly related to the transition time of the positive-going pulse. When the clock (CLK) input is at either the high or low level, the D-input signal has no effect at the output.
评论(0)
发评论
下载排行榜
