SN54F74,SN74F74,pdf(Dual Posit
消耗积分:5 | 格式:rar | 大小:653 | 2010-07-29
王飞云
分享资料个
These devices contain two independent positive-edge-triggered D-type flip-flops. A low level at the preset () or clear () inputs sets or resets the outputs regardless of the levels of the other inputs. When  and  are inactive (high), data at the data (D) input meeting the setup time requirements is transferred to the outputs on the positive-going edge of the clock pulse. Clock triggering occurs at a voltage level and is not directly related to the rise time of the clock pulse. Following the hold-time interval, data at the D input may be changed without affecting the levels at the outputs.
The SN54F74 is characterized for operation over the full military temperature range of -55°C to 125°C.
评论(0)
发评论
下载排行榜
