SN54ALS151,SN74ALS151,SN74AS15
消耗积分:2 | 格式:rar | 大小:792 | 2010-08-11
分享资料个
These data selectors/multiplexers provide full binary decoding to select one-of-eight data sources. The strobe (G\) input must be at a low logic level to enable the inputs. A high level at the strobe terminal forces the W output high and the Y output low.
The SN54ALS151 is characterized for operation over the full military temperature range of -55°C to 125°C. The SN74ALS151 and SN74AS151 are characterized for operation from 0°C to 70°C.
评论(0)
发评论
下载排行榜
