74ACT11139,pdf(Dual 2-Line To
消耗积分:2 | 格式:rar | 大小:523 | 2010-08-11
李艳
分享资料个
The 74ACT11139 is designed for use in high-performance memory-decoding or data-routing applications that require very short propagation delay times. In high-performance memory systems, this decoder is used to minimize the effects of system decoding.
The 74ACT11139 is composed of two individual 2-line to 4-line decoders in a single package. The active-low enables (1G\ or 2G\) can be used as data lines in demultiplexing applications. This decoder/demultiplexer features fully buffered inputs, each of which represents only one normalized load to its driving circuit.
The 74ACT11139 is characterized for operation from -40°C to 85°C.
评论(0)
发评论
下载排行榜
