SN74SSTL16847,pdf(20-Bit SSTL_
消耗积分:3 | 格式:rar | 大小:307 | 2010-08-19
分享资料个
This 20-bit buffer is designed for 3-V to 3.6-V VCC operation and SSTL_3 input levels.
Data flow from A to Y is controlled by the output-enable (OE\). When OE\ is high, the outputs are in the high-impedance state.
To ensure the high-impedance state during power up or power down, OE\ should be tied to VCC through a pullup resistor; the minimum value of the resistor is determined by the current-sinking capability of the driver.
The SN74SSTL16847 is characterized for operation from 0°C to 70°C.
评论(0)
发评论
下载排行榜
