TPD12S015,pdf(HDMI COMPANION C
消耗积分:5 | 格式:rar | 大小:1816 | 2010-08-24
张磊
分享资料个
The TPD12S015 is an integrated HDMI ESD solution. The device pin mapping matches the HDMI Type C connector with four differential pairs. This device offers eight low-capacitance ESD clamps, allowing HDMI 1.3 data rates. The integrated ESD clamps and resistors provide good matching between each differential signal pair, which allows an advantage over discrete ESD clamp solutions where variations between ESD clamps degrade the differential signal quality.
The TPD12S015 provides a regulated 5 V output (5VOUT) for sourcing the HDMI power line. The regulated 5 V output supplies up to 55 mA to the HDMI receiver. The control of 5VOUT and the hot plug detect (HPD) circuitry is independent of the LS_OE control signal and is controlled by the CT_CP_HPD pin.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
