SN65LVELT22,pdf(3.3 V Dual LVT
消耗积分:5 | 格式:rar | 大小:426 | 2010-08-28
分享资料个
The SN65ELT22 is a dual LVTTL to differential LVPECL translator buffer. It operates on +3V supply and ground only. The output is driven default high when the inputs are left floating or unused. The low output skew makes the device the ideal solution for clock or data signal translation.
The SN65LVELT22 is housed in an industry standard SOIC-8 package and is also available in TSSOP-8 package option.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
