SN75ALS197,pdf(Quadruple Diffe
消耗积分:5 | 格式:rar | 大小:703 | 2010-08-30
淡淡的爱
分享资料个
The SN75ALSI97 is a monolithic, quadruple line receiver with 3-state outputs designed using advanced, low-power, Schottky technology. This technology provides combined improvements in bar design, tooling production, and wafer fabrication. This, in turn, provides significantly less power requirements and permits much higher data throughput than other designs. The device meets the specifications of ITU Recommendations V.10, V.11, X.26, and X.27. It features 3-state outputs that permit direct connection to a bus-organized system with a fail-safe design that ensures the outputs will always be high if the inputs are open.
The device is optimized for balanced, multipoint bus transmission at rates up to 20 megabits per second.
评论(0)
发评论
下载排行榜
